mbc installed, no difference, still stock boost
Hey guys
Just installed mbc on my 96 850 turbo, didn't get aftermarket boost gage yet ,but i figured i'll keep the boost low to be safe until gage arrives. But to my surprise, seems like mbc isn't doing anything. No matter how many times i turn the **** on the mbc, no boost increase and the car feels the same everytime. I even used all new hoses to hook it up, to eliminate leaks. I am also pretty sure i installed it right way (wastegate to the side of mbc and turbo hose to the bottom). Don't know what to do. Can somebody point me in the right direction?
Thank you so much.
Thank you so much.
Ok maybe there is something wrong.
Try this BUT ONLY TEMP FOR TESTING!! disconnect the hose to the wastegate and test drive and see if it wakes up. If it does either the MBC is installed wrong like maybe the hoses need to be swapped or something is wrong with the turbo or intercooler hoses.
i think i figured out what was wrong with it, the compression spring was getting stuck inside mbc. way too thin in diameter for the inside of the unit. i found just right size spring at local home depot yesterday, and now it seems to be working, transimission downshifts better and the car feels much more aggressive. thanks for your help Tech.
Regards.
Regards.
Oshawaman
04-21-2012 07:32 AM
