First, a little bit of background information. We bought a T-5R a while back. Doing some research during the purchasing process, I found out the car's owner #3 blew a rod bearing and sold the car with blown motor to owner #4. Owner #4 swapped the engine out for a replacement B5234T engine, but moved over (at least some of) the bolt-ons from the original engine, such as the turbo and exhaust manifold. Owner #4 sold the car to me, whilst trying to hide he swapped the engine. Eventually I found out that he swapped the engine, and subsequently got the opportunity to buy the car at a low price. The motor swap was done quite poorly (wrong bolts, not well torqued etc.), so we recently decided to pull the motor to clean/fix/renew everything around the engine. Since we have driven the T-5R only 10km before doing so, we also aim to inspect the state of the engine. We have done the following things thus far:
- Compression test: all cylinders between 12.3 and 12.7 bar. - "Listen" to the engine: engine sounds perfectly healthy at idle and revving. -Cut open oil filter.Here, we found some metal in the filter itself (see images). The larger shiny chunks are non-magnetic, thus appear to be some sort of aluminum (?). Moreover, there are some very small magnetic particles present.
My questions are regarding these metal particles. - What do you guys think about this? Can one consider this 'normal' for older B5234T engines or should we be worried? - What components are likely sources of these metallic particles?
Final note: since the previous owner moved over some bolt-ons, could these particles also come from the turbo for example? The turbo does rotate freely and does not have excessive play though.
Really curious what you guys think! I am having a hard time deciding to pull apart the engine considering the great compression and general sound of the engine.
