metallic noise under glove compartment/dash
Sometimes I hear a very anoying metallic noise under the glove compartment of my 850 SW Turbo year 1995. This noise apparently doesnt have a pattern to show up..
Does anyone has an idea of the origin of such noise and how to fix it? Thanks all |
RE: metallic noise under glove compartment/dash
Is this sound like a loose metals hitting each other? or is it like a screetching noise? What is the frequency and is triggered by jumps/jerks?
If its close to the second then it could be from your blower motor ceasing. you can isolate that by turning the blower off as soon as you hear it. |
seems more like loose metals at each other. Definitely is not the blowe ´cause it happens when it is off. sometime begins even in idle in the garage.After a while it vanishes and then suddently happens again. I cant find a pattern for it to happen.
Thanks. |
Remove the lower dash panel on the passenger side. Then you will see a black metal bar. There is 3 nuts holding it on there make sure they are all tight.
I will do that and let you know if that was the issue.
Thanks a lot. |
This guy; see attached [8D].
JPN [IMG]local://upfiles/6892/1C8FD3FAE5984544AF3D87DFDA02BE65.jpg[/IMG] |
