My cam sensor came loose!
Old Apr 14, 2010 | 01:47 PM
rabraker's Avatar
Default My cam sensor came loose!
The Car: 93 volvo 850. I recently replaced the timing belt, head, headgasket etc due to broken timing belt from previous owner. The car ran great after I did all the work, and easily passed emissions.
To make a long story short yesterday the car died and restarted 2 minutes later. Died again today and would run, but VERY poorly
Pulled the codes, which were 324 & 314, both pointing to CPS. I took off the CPS cover and saw a bunch of tiny metal filings inside. I then began removing the inner black metal piece and found that the bolt was not completely torqued. Once removed, I found that one of the little tabs that fit into the slot on the camshaft was almost completely sheared off.
I *think* I remember torquing that 10mm bolt, but it was about a month ago so I can't be positive. Am I supposed to put loctite or something on that bolt? Any other reason it would have come loose? I'd rather not ruin my new sensor...
thanks,
arnold
mrbizi
May 14, 2011 05:35 PM
blue02
Apr 4, 2011 05:46 PM
spankey
Jan 2, 2010 10:26 AM
erndawg
Feb 13, 2009 10:14 PM
LeChasseur
Feb 7, 2009 09:46 PM
