New antenna mast won't get pulled in
Old Jul 3, 2010 | 12:40 PM
ajahn's Avatar
Default New antenna mast won't get pulled in
The antenna mast on my wife's 1997 850 would not go down. I pulled it out and realized that there was about 15" of chord still in the motor. Pulled out the assembly this morning, opened it up and removed the remaining chord (easy job, actually). Put every thing back and inserted the chord for the new antenna down in. Turned off the radio and it started to pull it in (about 2 inches) then stopped. Almost seemed like it was jammed. I was sure to put the teeth pointing in the right direction. I even took out the assembly and visually inserted the chord to make sure it was getting all the way down in and hooked it up to power in the car, and same problem... Doesn't pull the chord in. I can hear the motor when the radio is turned on/off, so I assume the motor is working.
Any suggestions? I hate to have to now turn around and buy a new complete antenna assmebly.
Thanks in advance!
Old Jul 4, 2010 | 08:15 AM
Are you installing a new mast?
The motor might be weak and when pressure is put on it the motor stops.
Old Jul 4, 2010 | 09:15 AM
ajahn's Avatar
Yes, I'm trying to install a new mast. I think you may be right, it seems like when the motor starts to pull the new mast, it stops. I found a used complete assembly on-line for $75 and a new one for $119. My Volvo is a 1997. I'm thinking the used one will save me money. It has a 90 day warranty. What do you think?
Thanks for replying...
Old Jul 4, 2010 | 09:49 AM
The used one should be fine for you. If it were my car I would go the used one as well.
MC92
Apr 19, 2009 09:11 AM
alecw81
Jan 7, 2009 05:22 PM
Crispin
Oct 12, 2007 09:28 PM
fast850r
Jul 27, 2007 09:32 AM
postdoc99
Feb 15, 2006 08:42 PM
