New cam sensor and still wont run...
i put in a new cam sensor and the car still wont start. i was out doing something yesterday and my car stalled out a few times but started back up then i went into a store and came back out and it wouldnt start at all. after doing a lot of reading and talking to people everything pointes to the cam sensor but after putting in a new one it didnt work. any other sugestions as to what it could be?
I would pull codes from the ECU. What model year is your 850?
Some of the popular causes for no-start: - Retiring fuel pump - Retiring fuel pump relay - Retiring fuel system main relay - Retiring MAF sensor - Retiring ECT (Engine Coolant Temp) sensor - Neglect - Etc... JPN |
its a 95 GLT
5 Attachment(s)
Is Check Engine Light on?
Try retrieving fault codes from the ECU: http://volvospeed.com/Repair/a2.html Your 850 is 1995 model so it has OBD-I terminal. See attached for additional info. Let us know if you need further guidance as to retrieving fault codes. JPN |
i fixed it. it was the fule pump. thanks for all the help!
You're welcome; glad to know your 850 is up & running again.
JPN |
