New guy, new vehicle and lots of questions.
1 Attachment(s)
Good morning folks, just found this site and been reading for a few days, LOTS of good info, thanks.
I just obtained a 1997 850 AWD wagon and although it is not bad shape (260+K) it does have some issues. First, I need to drop the fuel tank, it is leaking, can these plastic tanks be repaired or do I just try and source a good used one? Is it a PITA to drop the tank? Any pit-falls? Second, front right strut has flown the coop......:rolleyes: Needs to be replaced so I will do both sides, from reading I gather the best replacement struts are Bilstein TCs is this correct? If so, what is the part number? I plan on replacing the upper spring seats as well, I have the iPD part number of 112831 is this right? The rear suspension will be tackled at a later time. The only other glaring issue is a "shudder" when reversing, could this be the Vicious Coupling or..???? Thanks for any help and guidance and I look forward to participating in your site. Jeremy |
I just had a shudder when in stopped and at low speeds while in gear (reverse/drive) and it turned out one of the spark plugs was covered with butyl tape from the spark plug socket. I doubt that's your issue, but I figured I'd give my little bit of knowledge :p.
My advice, check the tranny fluid. If it's not bad, just drain it and add new fluid to it (make sure they give you the proper stuff, they sent synthetic when my car needs dexos). Change your spark plugs, I bought Bosch plugs since they're the plug brand that came in the car when it was new. That's all the stuff we did to my 97 850 GLT Turbo (automatic) to get her back on the road after being in storage. |
I do not have any advice on your questions, however rspi seems to be very knowledgable.
Originally Posted by BrendanL
(Post 361468)
(Post 361469)
Forum user.
Boxpin Edit: Forum Moderator |
You really need to find out where the leak is to determine if the tank needs replacing or not.
The tank is probably not leaking, its most likely a vent hose at the top of the tank that is cracked...very common. Not super difficult to replace. |
HERE I am. Lol
I have never owned a AWD model but it does sound like the rear drive shaft problem that many have experienced. Most people just remove the shaft and transform the car to FWD. Usually there is a line at the fuel tank leaking and not the tank itself. If the tank is bad you should get a used one I'd imagine. Most are satisfied with the Bilsteins and the spring seats that ipd sells are good. Get the heavy duty ones. |
The AWD tank is a real pain to take out as you first need to unmount the rear axle which is kinda of standing in your way.
So you need to take out the propeller shaft, the rear axle and so on ... Fuel tank from FWD will not fit. Here are the instructions for changing the fuel tank on the AWD https://www.dropbox.com/s/7lon1k05db...AWD%20Tank.pdf |
Thank you for the replies gents.........:)
From the sounds of it, if it is the tank or one of the hoses/fittings, I still have to drop the tank either way....... just looking at it and it does seem like it will be a PITA.............good link for removal....;) I replaced the complete front strut assembly yesterday with a good used one from a backyard "junk yard"......yes, I found one and removed it on a Sunday of a holiday weekend..........only cost $20...........:D I am ordering the complete Bilstein front strut rebuild kit from FCP tomorrow and am looking at a change in springs and shocks for the rear..... When and if I have to remove the drive shaft and axle to drop the gas tank I can check everything over and see if there is something obvious for the shudder in reverse......thanks again for the input.........one thing, man does this wagon have some get up and go..........:eek: |
Originally Posted by boxpin
(Post 361527)
Found the fuel tank leak...........:mad:
Turns out it is the tank itself and not a vent or fitting etc........the seam that joins the two halves of the plastic tank have come apart........I have found a good used tank at a local auto wrecker but they are not open again until tomorrow so as a short term fix I cleaned off the area and applied LIBERAL amounts of Seal-All and it appears to have stopped the leak...........NOT looking forward to replacing the tank........:rolleyes: PS. Any Volvo parts companies based in Canada that are competitive price wise with the US companies like iPD and FCP....? Trying to cut down on shipping costs and border taxes etc.... |
The tank from the breaker is also from an AWD right? FWD are different..
Originally Posted by scutyde
(Post 361668)
Yes it is from an AWD I realize they are different, thanks. ;) |
