New noise
Old Mar 16, 2018 | 08:25 PM
Phil 850's Avatar
Default New noise
My car suddenly started making an noise in the dashboard that sounds like a dry speedometer cable or stripped gears in a odometer. Is the speedometer mechanical? What about the odometer?
Old Mar 17, 2018 | 10:41 PM
firebirdparts's Avatar
It's electronic, but as you can see, there is a stepper motor in there running a mechanical odometer. There's no speedo cable.
Old Mar 18, 2018 | 03:38 PM
odometer gears regularly fail. you can find the replacement gears on eBay. only special tool required is a #8 torx bit screwdriver to open up the gauge cluster. Also a good time to replace any burn out dash bulbs...
Old Mar 18, 2018 | 10:32 PM
Phil 850's Avatar
I looked on youtube and the replacement of the gears looks pretty straight forward. I checked IPD and the gears are really cheap.
Old Mar 21, 2018 | 08:28 PM
Phil 850's Avatar
Well the source of the sound finally let it's self known. I was driving today and it was making the noise then suddenly made a bang then was a little quieter. When I parked and got out about half the rubber strip at the top of the windshield had pealed back from one end and was blowing in the wind. Now I need to see if it can be re attached or if the entire windshield needs to be reset.
Old Mar 22, 2018 | 05:00 PM
How funny! My 98 S70 did that, and it sounded like the noise was coming right out of the top of the dash. I saw it in a parking lot, after 3 or 4 days of it being really loud, and then figured out what it was.
Old Mar 22, 2018 | 11:40 PM
Phil 850's Avatar
This was the same thing, loud and sounded like gears in the dashboard. How did you fix it? Did you have to reset the windshield or were ?you able to reattach the trim?
Old Mar 27, 2018 | 01:32 AM
No, I just thew it away. The windshield is fine for now.
Heather202
Apr 25, 2016 08:54 PM
chimmychong
Apr 2, 2008 08:39 AM
ludeless
Aug 28, 2007 07:14 PM
twofourdee
Nov 28, 2005 02:48 PM
