new problem
Old Jun 29, 2007 | 02:42 PM
green850's Avatar
Default new problem
as some of you might have read, i discovered a crack in the radiator of my 1995 volvo 850 glt. so after pulling the radiator and patching the split with marine tex (good stuff rated to 8000psi) and letting it sit, the leak is fixed. but heres the problem the cooling system keeping drinking fluid and is not leaking it anywhere and is not in the oil. so does anyone have any ideas of what my problem is? i think something is wrong here because the breather tube coming outthe top of thethermostat housing has fluid pumping out of it (i was under the impression that it was simply a breather tube) into the expansion tank when it's running, is that soposed to happen?
if anyone has any input that would be great
thanks
Old Jun 30, 2007 | 08:21 AM
axelm's Avatar
Default RE: new problem
continued on your previous thread (so the whole history is on the samethread)
thexc90man
Mar 10, 2014 06:24 AM
analogies
Jan 6, 2013 03:41 AM
mrdjflores
Jul 10, 2010 02:38 AM
ca84dl
Jun 9, 2010 05:34 PM
drafter874
Feb 21, 2010 05:50 AM
