Newbie ???'s
Old Apr 17, 2006 | 06:40 PM
nottacop's Avatar
Default Newbie ???'s
Hi there. I am looking to buy a 95' 850 turbo wagon with 105,xxx miles on it and had a few ???'s.
I'm getting it for $2750.00
It has some body work to be done but it looks pretty smooth.
When driving it after giving it alot of gas it would stall out. I also noticed it wasn't as powerful as the other 850 turbo's I've driven. It felt like my old chevy on a cold morning.If I hit the accelerater to hard it would bog down. Could it be that the Turbo is going or is completely out? And is it an easy fix? How much for a new turbo?
The blower motor for the AC/Heat is also not working but hopefully its just a fuse.
What do ya'll think. Is it worth it?
Please help I might have to buy this soon.
Thankyou in advance, Notta...
Old Apr 17, 2006 | 09:08 PM
ludeless's Avatar
Default RE: Newbie ???'s
Do you know the service history of it? I would think a lot of things could contribute to it bogging down. Normal tune up stuff could help (plugs, wires, cap, air filter, cleaning intake). I just replaced all my vacuum lines as the old rubber ones just deteriorate after 10+ years. That made a big difference for me, that and cleaning up my intake.
How do the spark plugs look?
If you pull the hoses before the intake manifold, you can check to see how much oil is in them...some is 'normal' for a car that old, but a lot could be a leaky turbo maybe.
I don't know much about turbo's, as i haven't messed w/ mine...yet, but i think you can look at it to see if oil is leaking from the return line on the bottom side. I've heard you can check for play in the bearing, but don't know how to go about it exactly. I've seen new turbo's go for anywhere from 300-500, and rebuilt or used ones can be found for less...
good luck
Old Apr 18, 2006 | 11:05 AM
nottacop's Avatar
I did notice oil residue coming from the bottom of the pipe that connects the turbo. The thing is I know nothing of the history and maintince of this vehical. Scary but its a risk.
Old Apr 18, 2006 | 07:46 PM
info2x's Avatar
The blower might be more than a fuse. Does the fan have 4 speeds or completely variable?
Old Apr 18, 2006 | 07:57 PM
nottacop's Avatar
I believe it has an Auto setting then 1,2,3,4. How far into the dash is it or is it under the hood?
Old Apr 18, 2006 | 09:00 PM
The blower motor is under the Dash on the Pass. side.
If you replace it because it is bad also replace the resistor.
Old Apr 18, 2006 | 09:37 PM
nottacop's Avatar
What do ya'll think about a 97' V70. The guy told me that the gas milage was pretty good for a 4 cylinder. 4 Cylinder? Is this true?
Old Apr 18, 2006 | 09:57 PM
info2x's Avatar
There was no 97 V70. They were introduced in 98. V70s are also 5 cylinder
Old Apr 19, 2006 | 08:37 PM
ORIGINAL: info2x
Im not 100% sure but I think there was 1997 V70 in Europe.
Also they might be going by the production date.
I had one today that was a 3/1997 and listed as a 1998 S70.
Robert Carter
Jun 27, 2014 10:39 PM
Titch79
Jul 15, 2012 07:50 AM
funsox1
Mar 16, 2004 08:42 PM
Patty_in_cali
Jan 16, 2004 04:52 AM
bikerchris13
May 24, 2003 12:27 AM
