Non turbo upgrades?
Hi,
I was wondering if there were some reasonably cheap and easy things I could do to help out my non-turbo 850. I did the search and discovered not too much can be done with the engine, [ looks like simply buying a turbo car is the normal answer..] but how about some other things I could add on from other cars/models, to improve my cars handling and appearance. I regularly troll the junkyards and have access to cheap parts... any upgrade pieces I could snag from a turbo version as an upgrade? Better brakes.. suspension bits... something nicer looking than regular steel wheels... etc.? Any suggestions would be great. Cheers, Mike |
I think you have hit most of it on the head already. Wheels will change the look. You can get some suspension upgrades. IPD is a good place to start. I'd avoid bigger brakes since you will have the same engine performance anyways. For a real performance upgrade I don't think you can look past buying a turbo car. If you want to keep yours, do a stage zero to get it running as best as it can stock.
Originally Posted by vpatrol
(Post 218838)
Thanks for the replies. Yes, this is going to be the wife's car for work [so "looks" will be the most important thing to her... I'm more into the performance end of things.. **LOL**] , so if I can eventually find and turbo version [fwd or rwd...], I'll look into grabbing that one and doing the mods to it. BTW.. is either FWD or RWD better..... any advantage to running one form over the other? I prefer Rear Wheel Drive myself... Thanks for your input. Cheers, Mike PS... will all Volvo rims interchange or must I stick with FWD for this car?
