Non turbo upgrades?
Old May 24, 2010 | 09:12 PM
PAVolvo850's Avatar
Default Non turbo upgrades?
Hi,
I was wondering if there were some reasonably cheap and easy things I could do to help out my non-turbo 850. I did the search and discovered not too much can be done with the engine, [ looks like simply buying a turbo car is the normal answer..] but how about some other things I could add on from other cars/models, to improve my cars handling and appearance. I regularly troll the junkyards and have access to cheap parts... any upgrade pieces I could snag from a turbo version as an upgrade? Better brakes.. suspension bits... something nicer looking than regular steel wheels... etc.? Any suggestions would be great. Cheers, Mike
Old May 24, 2010 | 09:37 PM
vpatrol's Avatar
I think you have hit most of it on the head already. Wheels will change the look. You can get some suspension upgrades. IPD is a good place to start. I'd avoid bigger brakes since you will have the same engine performance anyways. For a real performance upgrade I don't think you can look past buying a turbo car. If you want to keep yours, do a stage zero to get it running as best as it can stock.
Old May 25, 2010 | 08:40 AM
imhereftw's Avatar
+1 You're absolutely right, sure you can make anything fast with the right amount of money, but it's really not worth it in your n/a
Old May 25, 2010 | 11:30 AM
PAVolvo850's Avatar
Thanks for the replies. Yes, this is going to be the wife's car for work [so "looks" will be the most important thing to her... I'm more into the performance end of things.. **LOL**] , so if I can eventually find and turbo version [fwd or rwd...], I'll look into grabbing that one and doing the mods to it. BTW.. is either FWD or RWD better..... any advantage to running one form over the other? I prefer Rear Wheel Drive myself... Thanks for your input. Cheers, Mike PS... will all Volvo rims interchange or must I stick with FWD for this car?
chithodt
Jun 11, 2015 11:20 PM
Ablorx
Jul 4, 2014 08:33 PM
phils94850
Jan 16, 2011 03:27 AM
CycleTron
Oct 24, 2010 02:26 PM
ROSS40
Feb 29, 2008 06:31 AM
