OBD Codes
Old Jun 2, 2012 | 10:38 AM
kleuch's Avatar
Default OBD Codes
Are the OBD codes the same for a 1994 850 non turbo as they are for a 1995 850 non turbo? I have a list for the 1995 but am unable to locate codes for my 1994. Also, the lead on the code reader is a bit frayed, can this be replaced or spliced? There is not much of the lead sticking out but it is still functioning. Thanks for your forum and your help..
Old Jun 2, 2012 | 09:39 PM
Yes the codes should be the same.
The repair would be at your own risk. You should be able to cut out the frayed part and shorten it or even splice in some extra if you need more length. Just make sure you follow the color codes of the wires. The wires they use are really small. Similar to the phone wiring of old.
Old Jun 3, 2012 | 06:38 AM
kleuch's Avatar
thanks for the response - i will check the codes to see why my check engine is on. i will also try to splice the lead - maybe not in that order - thanks again
phiber
Aug 27, 2008 07:36 PM
air force rascal
Apr 22, 2008 10:47 PM
Jamez2u
Oct 1, 2007 06:34 PM
volvo850sdca
Sep 21, 2007 11:18 PM
justin
Mar 15, 2006 01:29 AM
