OBD II code PO171
Old Jul 19, 2009 | 10:11 PM
maddox's Avatar
Default OBD II code PO171
Car is 1996 Volvo 850R Automatic transmission and the reoccuring code is PO171 - system too lean bank I. I had changed the front O2 sensor for other codes 3 months ago.
Any ideas? Thanks
Old Jul 19, 2009 | 11:54 PM
blackbrick's Avatar
check this link http://www.obd-codes.com/p0171
Old Jul 20, 2009 | 01:23 AM
stojakovic's Avatar
Always change both O2 sensors at the same time.
Old Jul 20, 2009 | 08:13 PM
maddox's Avatar
Thanks for the link. I will try these suggestions. The reason I didn't change both O2 sensors is replacing one took care of my problem before.
I will keep you posted.
Old Jul 20, 2009 | 08:18 PM
blackbrick's Avatar
This link suggested to use brake cleaner to clean MAF but I used only MAF cleaner.
Glad to help
Old Jul 20, 2009 | 11:18 PM
850tony's Avatar
Only use maf cleaner!!!!
Old Jul 21, 2009 | 02:47 PM
stojakovic's Avatar
Don't use aggressive cleaners such as brake cleaner to clean MAF.
Old Jul 22, 2009 | 01:09 AM
Ozark Lee's Avatar
Check the vacuum line that goes to the elbow on the passenger's side of the intake manifold - my bet is that you have a vacuum leak.
...Lee
Old Jul 26, 2009 | 07:58 PM
maddox's Avatar
I cleaned the MAF with electronic contact cleaner and it seemed to help but it was still idling inconsistently. Over the weekend I replaced the crankcase vent system and checked and replaced several vacuum hoses. I found a crack/rot on the bottom side of the short hose(this short hose also has a hose coming off it that goes to the AIC valve) that connects the throttle body to the turbo pipe. After I put everything back together now I have code PO 103 (MAF curcuit voltage too high). The car is very sluggish and actually cuts out under load about mid range and stalls now. Could this crack hose cause this? Please advise.
Thanks
Old Jul 27, 2009 | 11:15 AM
stojakovic's Avatar
Then probably you need to replace the whole MAF.
Old Jul 29, 2009 | 07:43 PM
maddox's Avatar
Well this thing started as a PO171 code and as it turned out after I replaced the intercooler hose to the throttle body, several vacuum hoses, and the crankcase vent system I think and hope I have solved that one. The car did much better after I replaced the cracked intercooler hose but still had severe stalling sometimes. I also had no codes.
I think I read if unplugging the MAF makes the car runs better then it is the MAF that needs replacing. Well it did that and it ran very good but would not idle very well and I also had PO102 MAF low input signal. I ended up cleaning the MAF sensor with electrical contact cleaner and it runs very good now. I will keep you posted if something else pops up.
Thanks for the help.
jchrisf
Dec 5, 2011 12:27 PM
Garman17
Apr 19, 2011 06:19 PM
kelanbec01
Oct 30, 2008 09:28 AM
chachouu
Feb 29, 2008 02:46 PM
gzh
Mar 21, 2007 09:29 PM
