OEM plugs from FCP Groton
Just recieved a 5-pack of Volvo OEM plugs from FCP and they have the 3-prong tip, which I'm not familiar with... I have the non-turbo 93 850 by the way... Does anyone know if they are pre-gapped, as well as being the right plug for a non-turbo (if it makes a difference?)
When I replaced the engine in The Anvil I went the distance and had almost everything reasonable done, including plugs and found the same thing.
The gap should be 0.028 in.
My understanding is that turbo plugs run at a slightly different temperature but if you ordered them online and entered the info correctly, then you should have the correct plugs.
[sm=icon_cheers.gif]
fcpgroton
Dec 11, 2010 06:04 PM
dads 740 turbo
Oct 2, 2008 01:05 PM
