oil cooler
Oil cooler is it the same as adding a transmission cooler. I mean on the passenger side is the oil lines can you tap into that with a cooler and a oil themostat
RE: oil cooler
What exactly are you trying to do?
RE: oil cooler
I have an extra oil cooler and was thinking of putting it on the car
RE: oil cooler
As long as your car is turbo then you could tap into the oil cooler lines either at the Radiator on the R/S of the car or at the cooler.
But I would not reccomend it. The Stock oil coolers work very well. The Non-turbo cars don't have oil coolers. I assume you are talking about engine oil cooler? |
