oil drain plug washer question
It would be steel and a M18 X 1.5
If you need a replacement right away most auto parts stores carry this size but their computer might not show it as an application. Need to look at the display to see if it's there. the Dorman part number is 090-167 at Oreilly, Autozone, NAPA ....
If you're replacing it I'd suggest getting a magnetic one. I have one from FCP. http://www.fcpgroton.com/product-exe...+Plug-Magnetic
I think the stock gasket is aluminum but you can use the plastic/nylon ones too, it's recommended to replace it each time.
And since decimal inch rulers aren't readily available, you'll have to convert to fractional 16ths:
Multiply 0.71 x 16 to get the number of 16ths inch.
0.71 x 16 = 11.36
11.36 = the number of 16th's of an inch. This is the numerator of the fraction. Apply the rules for rounding.
11.36 rounds to 11 because 0.36 is less than 0.5
Therefore, 0.71 in. = (approximately) 11/16ths of an inch
Or . . . . . (wait for it) . . . . . . . you could just say they are 18MM. Oh ya, I did say that. If you can't do metric, then it's 11/16ths
![Stick Out Tongue](https://volvoforums.com/forum/images/smilies/tongue.gif)
The Dorman part number good at NAPA, Autozone, Oreilly ... is 095-016 in aluminum.
And quit using those vise-grips to take out the plug !!
Through the marvels of "clearance" the tricky folks at Dorman market an 11/16 that also fits an 18mm
I was just amazed !!
You're really making me work for this one. (Good for you!)
Dorman AutoGrade - Oil Drain Plug Gasket
![](http://www.dormanproducts.com/images/Product/icon/095-016-001.JPG)
Type : Aluminum Size : 11/16", 11/16"SO, M18 Inside Diameter : 0.720"/18.29mm Outside Diameter : 1.060"/26.92mm Thickness : 0.080"/2.03mm Brand : Dorman - AutoGrade - Boxed
![EEK!](https://volvoforums.com/forum/images/smilies/eek.gif)
As long as it's fun, it's worth it. I was just trying to take a poke at the guy who said it was the size of a dime after I had said 18mm. To me size of a dime isn't all that helpful after you already have the exact size.
But then someone takes a poke at me because I'm rounding a decimal point. I love this forum
![Smile](https://volvoforums.com/forum/images/smilies/smile.gif)
Wow, how long can we keep a thread going about oil drain plug washers...?![Big Grin](https://volvoforums.com/forum/images/smilies/biggrin.gif)
I just get a few dollars worth when I restock my oil filters. Pretty cheap at IPD:
Oil Pan Drain Plug Seal Washer
Especially if you shop during their garage sale in May... extra 10% off.
BTW: I've re-used them multiple times w/o leaks; maybe 3 or 4x.
