Oil Drain Plug Washer
Old Dec 13, 2008 | 11:07 PM
hu5ker555's Avatar
Default Oil Drain Plug Washer
I just changed the oil in my 2005 S60 T2.5 for the first time (just bought it last week).
I bought the Mahle filter from IGN and it came with new washers for the oil drain plug. When I removed the oil plug, the old washer did not come off. Tried to pry it out carefully, but couldn't get it out. So, I just left it there and put the plug back in.
Next time I change the oil, any suggestions for getting the old washer out? How important is this? I checked the plug for leaks after changing the oil, and it seemed OK.
Old Dec 14, 2008 | 02:21 AM
TIPSP's Avatar
Got Boost?
Default RE: Oil Drain Plug Washer
As long as it doesn't leak, don't worry about it.
I reuse my washers all the time.
Old Dec 14, 2008 | 08:06 AM
The old one was compressed to much thats why it was stuck on there. It is only an aluminum washer you can cut it off with a pair of wire cutters.
Old Dec 14, 2008 | 11:30 AM
hu5ker555's Avatar
Since it is compressed into the drain threads, it is really difficult to tell where the washer ends and the actual threads start. Also difficult to get a set of wire cutters in there. I tried to pry it off with a really small flathead screwdriver, but couldn't get it.
Old Dec 14, 2008 | 07:56 PM
You will have to pry a little harder.
ibified
Jan 11, 2013 10:09 AM
ScottyJ
Jul 25, 2012 10:05 AM
brickrunner
Dec 12, 2011 01:19 PM
brickrunner
Oct 19, 2011 09:30 PM
98_V70_T5
Jul 22, 2009 06:49 PM
