oil in intercooler piping
Old Aug 1, 2010 | 12:43 PM
tater's Avatar
Default oil in intercooler piping
i started doing the pcv system and a tune up on my wagon. well i took off the upper intercooler hose to change the spark plug wires and noticed oil in it. well i took off the rest of the hoses and they all had oil in them. what would cause this and how do i fix it?
Old Aug 1, 2010 | 02:29 PM
Legendsecko87's Avatar
This is normal. PCV might fix it.
Old Aug 1, 2010 | 02:44 PM
kockyhardrockr's Avatar
check how much your oil goes down after driving. I was loosing about 1/6 the pan after a test drive from what i can only assume to be bad seals on the turbo leaking so badly that the car is actually sucking up some oil through the intake and burning it off. This is difficult to tell, but if your having turbo issues on top of other oil problems consider this. Rebuild kit shipped from Japan, lol. Should be here next week. 64.95
http://cgi.ebay.com/ebaymotors/ws/eB...%3AMEWAX%3AVRI
Old Aug 1, 2010 | 05:27 PM
fcpgroton's Avatar
Former Sponsor
If there isn't a lot of oil pooling in there, then that is normal. If it seems excessive, then it is probably because of the bad PCV and it should resolve itself once you are done replacing it.
Old Aug 1, 2010 | 08:08 PM
gilber33's Avatar
It's normal. The main hose from the PCV system will carry some oil in and dump it back into the intake hose. Add a catch can if you want o lower that amount of oil that goes back into the intake if you wish.
Old Aug 3, 2010 | 02:16 AM
My PCV was just replaced not even 1000 miles ago. oh wait, that could be from the hoses being switched on the flame trap. I'm gonna write that down and look. Still my turbo boost issues wouldn't be corrected by the PCV hoses being switched, rebuild was needed.
65fastback
Jul 25, 2014 04:43 PM
Flasher
Jun 23, 2009 11:09 AM
elcs70
Dec 21, 2008 07:32 PM
92Typhoon
Jun 5, 2007 12:10 PM
bigmayo21
Jun 5, 2007 07:49 AM
