Oil smoke question
Old Jul 11, 2008 | 08:47 AM
Psaboic's Avatar
Default Oil smoke question
Question about my son's 850. We have noticed latelythat if he parks the car nose down on a slight slope (about 2% of slope) in the parking lot at work, it will let out a moderate puff of blue smoke on start up.
It only does it when parked nose down, and only after sitting for more than about 5 hours. The rest of the time it starts fine, (no smoke) doesn't burn oil on the highway, and only uses about 1/2 a quart of oil every 5000 miles. What problem(s), if any, might be lurking. Oyh yes, car is a 95 turbo sedan with 190K on it running full synthetic oil on 5000 mile oil change intervals.
Glenn
Old Jul 11, 2008 | 05:04 PM
Spike555's Avatar
Default RE: Oil smoke question
Oil is seeping into the combustion chambers. Most likely worn valve guides. When he is parked on the slope oil is overtop of the leaking guide and seeps into the cylinder. When the car is level the oil inside the head drains back into the oil pan faster than it leaks into the cylinder.
No worries, until it happens everytime he parks the car dont worry about it.
Old Jul 12, 2008 | 09:28 AM
Psaboic's Avatar
That is pretty much what I thought and what I told him. However he would not believe me until he read it on the forums.....go figure <grin>
Thanks
Glenn
Old Jul 12, 2008 | 09:31 AM
I still have yet to see a set of worn guides. You replaced all PCV parts correct?
Old Jul 12, 2008 | 09:36 AM
Psaboic's Avatar
Actually, the PCV is on the list to do at the next tune up. Never thought about it as a cause of the occasional smoke. Maybe I might want to do it sooner.
Old Jul 12, 2008 | 09:42 AM
Spike555's Avatar
If he is parking nose down then the oil could be getting into the PCV system.
Here is a easy test to see if it is the guides or not. Switch to a thicker motor oil. If it still does it then its the PCV system, if not, then its the guides.
Old Jul 12, 2008 | 10:21 AM
If something clogs up or becomes somewhat plugged up it tends to pump a little oil into the intake.Also make sure all vent system hoses are connected.
Old Jul 12, 2008 | 10:27 AM
Spike555's Avatar
Is there a way to clean the PVC system? If I pour a can of Seafoam into the tube will it clean the system? Or is it a repair/replace only?
Old Jul 12, 2008 | 11:40 AM
Pretty much repair/replace only.
Old Jul 12, 2008 | 11:53 AM
Spike555's Avatar
Ok, thank you.
I tried to clean the t-body today but man, I cannot get to it.
Old Jul 12, 2008 | 11:57 AM
That should be easy to get to.
Old Jul 12, 2008 | 07:02 PM
Spike555's Avatar
The t-body is down behind the engine next to the turbo. I need to remove the air intake and the intercool tubes.
Old Jul 12, 2008 | 07:53 PM
The throttle body is on the side of the intake manifold up front on the engine.
Old Jul 12, 2008 | 07:58 PM
Spike555's Avatar
I followed the air intake tube from the air filter box and it leads to what looks like a t-body. The intercooler tube runs to it also. The only thing on the front of the engine is the injector rail and the intake manifold and it looks like it runs from the back of the engine where I think the t-body is to the front of the engine. I see nothing on the front that looks even remotely like a t-body. But I will look again tommorrow.
Old Jul 12, 2008 | 09:04 PM
Remove the black cover and follow the intercooler hose from bottom of the Radiator to the motor.
Old Jul 12, 2008 | 09:32 PM
Spike555's Avatar
OK, I will check into that tommorrow when it is light out. Thank you. This is my first Volvo and so far ir is alot different than anything else I have owned.
Old Jul 14, 2008 | 07:52 PM
  #17
Spike555's Avatar
OK, cleaned the t-body, it was black. Used a whole can of carb cleaner.
Now for the O2's.
Old Jul 14, 2008 | 08:08 PM
  #18
Did it run any better after the cleaning?
Old Jul 14, 2008 | 08:12 PM
  #19
Spike555's Avatar
Cant post
Old Jul 14, 2008 | 08:14 PM
  #20
LOL I know the feeling same here.
