Oil Under the Spark Plug Cover
Old Jan 4, 2008 | 10:42 PM
94_850T's Avatar
Default Oil Under the Spark Plug Cover
Is the most likely cause a bad seal on the oil filler cap? When I took it off there was a significant amount of oil underneath. I replaced the cap seal. The old one was rock hard, and the new one felt like it sealed MUCH better.
I really just wondering what the other possible causes are. I plan to keep an eye on it. I'm hoping that I solved the problem.
Old Jan 5, 2008 | 02:51 AM
JPN's Avatar
JPN
Default RE: Oil Under the Spark Plug Cover
That is acommon symptom for the 850s. The new filler cap gasket will seal a while but after a little while it'll start leaking again. To stop this, you would want to replace the PCV components, as old PCV system allows the crankcase pressure to build up. I would also replace the dipstick O-ring, since it is less than a dollar.
JPN
Old Jan 5, 2008 | 06:25 AM
JimKW's Avatar
Yeah just what JPN said. The best place to get the pcv replacement parts is fcpgroton where the sell a kit designed especially for your car. Search through here and you will find several threads on changing the pcv system. Good luck.
Old Jan 5, 2008 | 10:57 AM
Psaboic's Avatar
Changing that seal is definitely a step in the right direction.
Old Jan 7, 2008 | 01:48 PM
Systek's Avatar
yep, i have the same problem
Old Jan 7, 2008 | 04:33 PM
ikes4ever's Avatar
if theres too much pressure in the crank case and you seal up the oil cap to well. wont it just start blowing out other seals(i.e. rear main or head gasket). had this prob with my buddies 83 240 DL years ago.
BPATR1CK
Oct 3, 2010 07:55 PM
ajwgator
Jun 26, 2010 08:26 AM
TacklaNHL
Jan 22, 2008 02:16 PM
lanciak66
Jan 1, 2007 06:58 PM
eyukins
Sep 15, 2005 09:50 PM
