out side air temp
Old Aug 23, 2005 | 09:49 PM
audios's Avatar
Default out side air temp
where is this sensor located? anybody have aclue? mine is reading awful high.......
Old Aug 24, 2005 | 12:01 PM
rp850's Avatar
Default RE: out side air temp
I believe it's behind the front grill on the driver's or passengers side. What do you consider high? I've seen as high as 120, especially if you park next to something like a parking curb. It reads the temp off the street to some extent.
Old Aug 24, 2005 | 12:35 PM
audios's Avatar
ive seen 129+.....its hot out here but not that hot. does anybody know of a fix for this????
thanks
bill
Old Aug 24, 2005 | 02:51 PM
rp850's Avatar
That's pretty high but I could almost believe it especially if the sensor is somehow in close proximity to either a hose on the car or something. What's the real outside air temp when this happens? Does the display go down in temperature if you drive on the highway? Check under the front bumper for it near the center of the car but a little towards the driver's side. I think it has a grey connector.
Old Aug 24, 2005 | 08:55 PM
It is either hooked in a metal bracket in the hole in the bottom part of the bumper or it is located in the Air guide.
Old Aug 25, 2005 | 12:55 AM
robert213's Avatar
I have heard of faulty oil pressure sending units and water temp sensors causing electrical fires.
Once you find that little guy, feel the wires going to and from it. If they are hot to the touch, disconnect and wrap connector with electrical tape.
cc sbrider
Sep 27, 2014 03:16 AM
AnEskimo
Mar 7, 2014 08:29 PM
blackbrick
May 7, 2011 01:46 PM
vcolper
Nov 1, 2006 10:20 PM
