PCV System Post Replacement Issue
Old May 29, 2009 | 09:14 PM
denver005's Avatar
Default PCV System Post Replacement Issue
Installed a new PCV kit from ipdusa last weekend. Notice improvement in the idle speed vibrations, etc. I re-checked the hoses today and notice a split in the elbow that connects to the PTC on the inlet hose. Has anyone experienced the same problem? I may have to reinstall the PCV hose. Is it ok to tape it tight? See attchached picture.
Year: 1996
Vehicle: Volvo 850 Turbo.
Old May 29, 2009 | 09:36 PM
850tony's Avatar
if you do a really clean job of taping it with electrical tape, that will prolly get you by. personally i would run down to my local hardware shop and just buy a section of hose the same diameter and a case of bear and install it and drink it (my hardware store and liquor store are the same store... small a$$ town haha)
Old May 29, 2009 | 11:08 PM
nonsense619's Avatar
replace the hose...you dont want a leak
Old May 30, 2009 | 12:56 AM
arzy's Avatar
I had the same problem, the kit from FCP comes with spare elbows. There are easy to replace. No need to replace hose. Simple fix.
Old May 30, 2009 | 01:45 AM
elbow/hose same thing..lol..were reffering to the same thinng
Old May 30, 2009 | 08:42 AM
denver005's Avatar
I thought the elbow is a sealed/glued attachment to the hose? I am going to check with the parts dept of a Volvo dealership today. I will post soon.
Old May 30, 2009 | 08:52 AM
You can get it seperate.
Old May 30, 2009 | 10:02 AM
denver005's Avatar
I am trying to guess as what caused the elbow to fail after just one week replacing the entire PCV system. Is it possible pressure could build up if the vaccum line is blocked due to a bad/blocked PTC? I did clean the PTC.
The vaccum line is connected to the inlet manifold.
Old May 30, 2009 | 11:26 AM
Well if you did not replace the hose before than maybe from you moving stuff around and it put pressure on the older one and it just let go.
Old May 30, 2009 | 11:44 AM
denver005's Avatar
I replaced the oil trap and all hoses.
http://www.ipdusa.com/version.asp?st...849&V_ID=12576
Old May 30, 2009 | 12:30 PM
It looks like it was new. I would contact IPD about getting another of the small hoses that cracked.
mhutchens
Jun 25, 2021 06:46 PM
rspi
Jan 11, 2014 06:57 PM
rspi
Nov 20, 2013 10:03 PM
BCV70
Nov 26, 2012 05:32 PM
dequinox
Apr 14, 2010 12:08 AM
