Polly Upper Mount
Old Jul 14, 2009 | 06:06 PM
gilber33's Avatar
Default Polly Upper Mount
Installed the polyurethane upper engine mount as well as the upper torque mount from IPD last weekend. Since then, when I come to a complete stop, and you get that little feeling like you go backwards right at the end of it, well anyways, when that happens I get this little "creak" and it sounds like it's coming right from that area. Could that just be the fact that I have two new engine mounts, one being stiff, that they're just "settling" in? I don't know what else it could be since it's only happened after I installed them. Curious if that happened to anyone else who has used them.
Old Jul 14, 2009 | 06:40 PM
850tony's Avatar
sounds like the bolt from the side that goes to the motor on the upper isnt all the way tight...
Old Jul 14, 2009 | 06:45 PM
gilber33's Avatar
You mean the bolt that actually goes into the engine?
Old Jul 14, 2009 | 07:22 PM
850tony's Avatar
no. the bolt that goes through the motor mount.
Old Jul 14, 2009 | 07:31 PM
gilber33's Avatar
I took it for another test drive and it was obvious that's where the sound was coming from, but everything seemed tight, maybe I have to tighten the bolts that hold the torque mount. I checked it, I tightened it some, and then tightened the torque mount. I don't know, I thought I had tightened everything pretty good. Maybe I'm just being paranoid.
CaliS80T6
Sep 12, 2009 09:20 AM
leebae
Jun 17, 2007 10:28 PM
00XC
Jan 3, 2007 04:09 PM
adub96
Nov 19, 2006 07:18 PM
Red XC
Apr 8, 2006 03:11 PM
