Possible Cat Problem
HI all,
My 1994 850's turbo was replaced some months back and was running fine and it still does, but once in a while when I am driving and use the turbo I will get a bad smell from the exhaust. Recently my lambda light came on, i used the ODB II and it it shows no pending codes but the EGR and CAT buttons at the top of the screen are flashing, but no error codes (just a yellow warning light on my ODB). I replaced my 2 oxygen sensors recently, if the cat is bad it will likely foul up my new sensors yes? I don't feel or see any exhaust restrictions, since i was thinking the cat was bad or blocked, wondering if the cat is old and needs changing and the reason for this bad smell. There is a small leak in the exhaust pipe after the cat where it connects to the remaining pipe but not from rust, it is just a small space where some condensation leaks out. Anyone also know the exhaust diameter on my car? thanks to all! |
2.25" I think.
