power for new stereo
Old Apr 30, 2008 | 06:36 PM
vetalbig's Avatar
Default power for new stereo
hi everyone,
i had a lot of trouble with my original volvo stereo somy sister got me a new kenwood. after installation everything works just finebut it won't keepsettings after turning ignition on or off!
what power wire should i connect it to so it won't loose all settings every single time?
thank you for your help,
regards,
Alex.
Old Apr 30, 2008 | 07:14 PM
Default RE: power for new stereo
Did you buy the harness adapter?
If not I would have to look at a wiring diagram to tell you.
On the new radio itself I think it will be yellow.
Old May 1, 2008 | 05:53 AM
ShaginWagon's Avatar
I recon you have the "ign" and "+ve" wires swapped.
Old May 1, 2008 | 08:25 AM
green850's Avatar
when I put my head unit in, the ignition wire was blue i would check that
Old May 1, 2008 | 08:37 AM
Psaboic's Avatar
Yep, you definitely want to connect to a constant 12 volt source, not a switched source.
ggw
Apr 21, 2018 10:34 PM
nkhlystov
Dec 14, 2010 01:30 AM
tanjung66
Oct 9, 2007 09:49 AM
caveternal
Jun 24, 2005 03:28 AM
