problem with 95 850 turbo "turbocharger" itself.
My trubo seems to be making a high pitched whistling noise. One of my buddies who builds cars told me it might be an oil leak from the turbo itself. It does seem like I am loosing oil somewhere and I can smell it burning on something hot. Which would all make sense. Now If this does sound like a leak would it be the turbo itself going bad (i.e. shaft loose) or something like the oil line? I didn't get around to pulling the cover and intake boot yet to check it out.
Also, how is the thermostat on these cars to do? |
RE: problem with 95 850 turbo "turbocharger" itself.
Search for the post I made around last NOV/DEC. It contains the links to several do-it-yourself procedures on replacing your thermostat. Highlights -- the only place to find an 87C/190F thermostat is at FCP Groton -- no longer available at the dealer; A LONG shaft torx bit is REQUIRED. Do NOT overtighten thermostat housing.
It is not a difficult task. It took me awhile to figure out how to loosen fuel rail. I had some trouble unpluging (without prying/breaking it) the electrical connector for Engine Coolant Temp (ECT) sensor. I ended up using pinch-nosed pliers to pull on wire bullet pins. If you are led to believe that your turbo has a problem... Does your engine use more than 1/2 quart of oil per thousand miles? Remove the intercooler pipe between turbo and intercooler. Do you see a thick oil film inside of pipe? Remove the turbo inlet hose between air filter box and turbo. Do you see oil puddled inside of turbo housing? Firmly pull on turbo compressor wheel. Is there a lot of slop and play in the turbo shaft? Have your current turbo rebuilt professionally. It shouldn't cost much more than $300. Remember to purchase and install a new turbo oil feed line. And one other thing... For the price of a rebuilt, your existing turbo housing can be over-bored for a larger compressor wheel, such as -15G, -16G, -16T, or -17C. Shop and compare... http://www.forcedperformance.net/ Forced Performance 671 New Hope Road West McKinney, TX 75071 Phone: (972) 984-1800 Fax: (972) 984-1802 Sales@forcedperformance.net Rebuild@forcedperformance.net http://www.turbochargers.com Turbochargers.com 5410 Burr Oak Drive Houston, Texas 77092 Tech Line: (713) 681-1111 Order Line Toll Free: (800) 749-7111 Fax: (713) 939-1111 Email - Turbo@turbochargers.com http://www.dallasturbo.com/ Majestic Turbochargers of Dallas 1000 S. Wildwood Suite 10 Irving, TX, 75060 http://www.hirschinds.com/ HIRSCH FOREIGN P.O. BOX 18063 PHOENIX, AZ 85009 |
You could also have a turbo return line leaking the seal goes bad at the block. It is infront of th exhaust on the block. They are known to leak. But it could also be Cam seals or Rear main seal.
Cam,Main, or Return line would cause the high pitched whistling noise?
Well mine makes a high pitch whistling noise, and I think I have a leak too. However there is what is also called turbo whine which is normal.
Well mine makes a high pitch whistling noise... |
