Proper adjustment of wastegate actuator
Old May 13, 2011 | 12:49 PM
ibified's Avatar
Default Proper adjustment of wastegate actuator
In the middoe of swapping my turbo on the car and had a question about the wastegate arm: I'm installing a new one on the new turbo (didnt come with one) and was wondering if there should be any tension on it when it's sitting on the bench. I want to make sure I have this thing set right, because it's a lot easier to adjust with it out of the car. Thanks all.
Old May 13, 2011 | 09:44 PM
clean850R's Avatar
On the factory set-up if you apply 4psi to the waste gate and then set the rod on to the flap with the door closed. This sets the waste gate to start open at 4 psi. I set my stock one to open at 5psi it spools up quicker. and won't open until at least 5psi of boost! Unsure for the turbo you have if your running higher than stock pressure you can probably set it around 7 or 8 depending in how high your boosting. Hope that helps alittle!
Old May 13, 2011 | 10:19 PM
Mad Matt's Avatar
Clean850R is spot on. There is a really good video that iPd did called turbo 101. You can find it on YouTube. That will show you exactly how to do it. You need to be a little on the careful side as not to build boost too fast and develop too much Tq in the lower RPM range. There is a real possibility of bending rods even in stock form. I had my wastegate set at 5.5psi on my iPd stage I tune and it ran great and started to build boost about 2,800RPM.
It's really easy once it's in the car, set it at 4psi and adjust it from there to fine tune it to where you like it. just leave the heat shield off till you get it where you like it.
Old May 13, 2011 | 10:24 PM
Carrots's Avatar
Be careful to use the right setting! LPT motors use 2.6 PSI, there's others that use 1.8 PSI... make sure you use the right setting.
Old May 16, 2011 | 12:23 AM
ibified's Avatar
Thanks for the input everyone. I got the new turbo and exhaust on this weekend and all is well.
birdman_s80
Jan 30, 2024 10:51 AM
ENDEE666
Jan 29, 2024 01:33 PM
elcs70
Nov 19, 2011 02:03 PM
poor_red_neck
May 6, 2009 11:49 AM
helps
Jul 17, 2008 01:54 PM
