radiator drain plug
RE: radiator drain plug
And if the remaining portion is still stuck in there, take a hex (allen) socket or equivalent, hammer it into the hex hole in the plug and you should be able to turn it off.
When you install it, all you need is finger tight + 1/16 to 1/8 turn. It is tempting but since it has an O-ring, it does not need to be tightened hard. If it leaks, give it additional 1/16 turn until leak stops.
JPN
JPN
jbarnes
06-12-2013 11:46 AM
MrReality
04-05-2013 03:28 PM
