Radiator Fan Issues
Hey.
My radiator fan is refusing to come on at idle and is causing my engine to overheat. Are there any methods I could use to determine whether the fan motor has gone bad or if it is something different? Thanks for any input! |
try jumpering the relay to see if you can get it to kick on. if it kicks on then you should replace the relay. could also be a temp sensor so you may want to measure that as well. does the car have warm start issues?
I use a volt meter to determine where power is going. I always say half of life's problems require a volt meter to solve.
Originally Posted by mt6127
(Post 431061)
Yep, just shoot 12 volts directly to the motor with jumper wires. That will tell you if the motor is good or not.
