Radio Help!!!!
Hey guys...I disconnected the battery on my '96 850 and totally forgot about the radio lock. Anyways, I called the dealership Monday and got the code from them, however, this code isn't working. Is there a "backdoor" to get past this code or anything else I could try? The dealership insists this is the correct code for my VIN.
Sometimes if you try the wrong code more than a few times or playing with it while it's locked, the radio will completely lock itself. I think you need to turn the key on and let the car sit for a couple hours or something like that and then it goes out of that "lock" mode and you can enter the code.
Radios that came with these cars aren't always the one currently in them and some dealerships were not real good at updating the database when they changed one out (you know, 'cause of warranty issues). You'll have to go to or call a dealership with the radio serial number and part number (you really don't need the VIN) The serial number and part number are on a sticker on the top of the radio.
Also, you can only put your code in when the display reads "code" (which it seems like you know).
Just pull the radio out and throw it in the trash. Go get a new $99 Pioneer and a plastic filler compartment at Walmart and you'll have better sound and gain a nice place to store a few CD's. I did it 4.5 years ago and have no regrets. My radio didn't have a CD player though.
The radios are very simple to pull. Move the shifter all the way to L, then use a coin or small screw driver to push in and pop out the tabs on either side of the radio. Pull on the tabs to remove the radio. You don't need to pull the radio all the way out, just enough to view the sticker on top.
More pennies to save! After I get new rubber all around I've got my eye on a Pioneer Premier double din deck with DVD player and screen. Gotta get the driving and ride right before worrying about entertainment! Or get a better paying job!
rspi
04-12-2013 04:21 PM
850keeterbeata
09-25-2009 04:33 PM
