Radio Resets
Old Nov 8, 2011 | 05:27 PM
spaceman's Avatar
Default Radio Resets
1995 Volvo 850 Wagon
I need a radio reset 4 digit code for my car. I've seen so many people asking but no real constructive help.My local dealers have been less than helpful. Doesn't anyone know the codes?
Old Nov 8, 2011 | 06:12 PM
SVolvoD4's Avatar
As far as I know, only the dealers have them, call all of them, even ones not in your area, in my experience they just ask for the vin, though some need verification. Also, have you tried calling volvo? They might have it. Try Jim Fischer Volvo 503 295 5571 just ask for the radio code and have your vin on hand...
Old Nov 8, 2011 | 06:24 PM
fcpgroton's Avatar
Former Sponsor
That is correct. Every radio has a different code. You can only get it from the dealer so if your current dealer is not helping, call another one.
Old Nov 9, 2011 | 06:53 AM
spaceman's Avatar
Default Radio Codes
Thanks folks.
I'm not sure why the local dealers are being so reluctant to help. I will try the numbers suggested.
Cheers
Spaceman
Old Nov 10, 2011 | 05:50 PM
spaceman's Avatar
Well I got the code. I cannot get the radio back to where I can actually enter the code. I took the fuse out. I disconnected the battery...neither worked. I'm stuck.
Old Nov 10, 2011 | 06:13 PM
SVolvoD4's Avatar
If you disconnect the battery and reconnect it, turn on the car and radio, the CODE message should be the first thing to pop up. When you do this, is nothing happening? or are you getting an EEEE message?
Old Nov 11, 2011 | 05:18 PM
spaceman's Avatar
Hi
I disconnected the battery and after 2 hours re-connected it. When I turn the radio back on/ power on it says "OFF". I just can't seem to get back to the place for entering the code.
Spaceman
Old Nov 11, 2011 | 06:23 PM
fcpgroton's Avatar
Former Sponsor
You need to leave the car in the on position with the battery connected for two hours. Once the radio is on for 2 hours straight, it will say code again.
Old Nov 11, 2011 | 07:41 PM
SVolvoD4's Avatar
+1
Old Dec 11, 2012 | 07:45 AM
rhenry4309's Avatar
Default 1995 Volvo 850 radio code
I replaced my radiator, t stat and hoses and had the battery disconnected...came up with a radio code and since I bought it used from a third party had NO IDEA where to find it. The radio said "OFF" on the display so today I disconnected the negative terminal on the battery for about ten minutes and when I hooked it back up, somehow it bi passed the radio code and now the radio code works....maybe this will be helpful for some.
I had heard that on some models if you hold in preset button 6 while turning on and off it may bi pass...any ideas??? Thanks
Old Dec 11, 2012 | 08:03 AM
No, just have to wait the 2 hours with it on. I had one that went to CODE after I drove around for 2 hours (20 minutes here, 40 minutes here, etc.), didn't have time to let it sit. Anyway, you can try a bunch of tricks and let us know what works. So, disconnect your battery so it asks for the code, enter 3 random wrong codes so it says OFF, play with some tricks and let us know what it takes to get CODE back and let us know.
Old Dec 11, 2012 | 08:03 PM
As for finding the radios code, you can also look in the owners manual. I know mine was already recorded in the back of it. Makes sense someone stealing the radio isn't going to take the time or even think of taking the owners manual too
Old Dec 11, 2012 | 08:20 PM
I alway write mine on the passenger side vanity mirror flap (inside). That way if I reach down to turn on the radio and it says CODE and I can't remember it at the time, I can flip that down real quick and see it.
Old Dec 12, 2012 | 06:54 AM
rhenry4309's Avatar
Default Radio Code
Yeah I thought that it was going to work, the radio played for about 10 mins then shut off and went back to "code." As for when the radio says "off," I disconnected the negative terminal for about ten mins and when I re connected it the radio went back to saying "code." I did a search online and went to a website named justanswer.com, where they have volvo techs that can get the radio code for you; you just have to provide radio type and vin. It cost me $18 but once I submitted the question, I received an answer in a couple hours with the radio code....I put the code in and everything works fine. I know it costs money but it was less of a hassle then trying to get it from the dealer. Hope this may help some....
Old Dec 12, 2012 | 12:01 PM
ES6T's Avatar
Good source of information if you get an expert who is actually a Volvo tech... trust me.
Old Dec 12, 2012 | 03:05 PM
JimKW's Avatar
Some dealer will give you the code if you just call them and give them the VIN. You can also get it using the serial number from the head unit, just in case somebody switch head units from another Volvo.
Old Dec 12, 2012 | 03:39 PM
  #17
It's just sad that you had to pay to get it. Likely a dealer tech who took your info, went to work and punched it in and made some $$ on the side.
The other thing is if someone stole my radio I'd like to think it would be harder than paying some guy a few bucks to use my radio in their car.
Old Dec 12, 2012 | 03:46 PM
  #18
ES6T's Avatar
Information removed.
Old Dec 12, 2012 | 04:38 PM
  #19
Originally Posted by ES6T
There isn't exactly a booming market for Volvo radios. It wouldn't be harder anyway, since a lot of dealers give the code over the phone instead of requiring you to come in with registration. And even then, someone could say they bought the radio on ebay.
Great point, have no idea what I was thinking of but it really wasn't a 90's Volvo radio that's a double DIN and wouldn't fit most cars anyway !!
I'm blaming it on the spiked eggnog !!
Old Jan 3, 2013 | 01:07 AM
  #20
Calyn's Avatar
Leave the radio on with you key turned to position 1 for 2-3 hours. turn off your lights to conserve battery..ect..
