Re-Torque Head Bolts that were too loose?
Old Jun 29, 2018 | 02:36 AM
Dmck's Avatar
Default Re-Torque Head Bolts that were too loose?
So after doing research I have realized I did not torque my head bolts down correctly on an 95 850 turbo sedan.
I only did the final 130degree sequence (in three stages) and not the 15 and 44 ftlb sequences.
The only time I get burned coolant coming out of exhaust is when my radiator fan turns on. I'm guessing this means my coolant temp must need to get to boiling before it seeps into cylinders.
There is no issue with coolant in my oil, or oil in my coolant, or pressure build up in my coolant tank, so I believe the rest of the head gasket is sealed and only the metal rings on the head gasket around the cylinders are compromised.
I know the proper thing is to just do complete head gasket redo, but I want to gamble and try to re torque the bolts.
If you were as dumb as me and wanted to try to take the easy way out would you:
A) just torque all head bolts down around 15 more degrees
Or
B) loosen all head bolts and retorque them all to proper spec.
I understand neither of these are correct and I should just do full head gasket job. This is my personal vehicle, so me doing something stupid will only hurt me.
Old Jun 29, 2018 | 05:14 AM
860ARE's Avatar
I just torqued down mine and wrench us junk wouldnt to the inital setting. So i tightened them tight then did the 130 angle. Its definately tight. But if mine does leak im going to replace gasket and start over. I hope its good.
Old Jun 29, 2018 | 09:19 AM
tony1963's Avatar
I hope it works. That's a lot of work and cost to start over.
Old Jun 30, 2018 | 09:04 AM
tryingbe's Avatar
Leave it.
turboxr
Nov 18, 2011 06:52 PM
seanmathes
Feb 4, 2010 09:32 PM
velora
Nov 10, 2009 10:33 PM
rules
Oct 29, 2009 03:54 AM
keith
May 8, 2007 05:01 PM
