rear coil springs
1 Attachment(s)
hey guys it looks like the left side of my rear is dropped a lil bit than the right side. its not straight.what could be the problem?springs?
Attachment 5885 |
springs or shocks are blown. Shock mount blown.
l just replaced the shocks with sachs.l think its the springs
Shocks don't control ride height its going to be springs. Your going to need to confirm they are seated.
why is it that when it is very very cold outside my ride becomes very stiff with less body roll, but when it gets warm my ride losens up and there is more body roll and my dash board rattles when going over bumps.but when its very cold outside it never rattle over bumps cuz the ride is very stiff.could it be the springs getting weak and losens up when warm and it freezes up when its cold making the ride stiffer?
1 Attachment(s)
Originally Posted by boxpin
(Post 309662)
If a shock mount failed you would usually have a knocking sound in the rear that was hard to locate and again you might loose a little height but I doubt you'd notice it. I lost one and couldn't tell from side to side any difference in ride height. Like Boxpin, it's likely you have a spring starting to fail or it's shifted off it's seat or maybe broken off a coil or two. Most shocks have oil in them. The valving is what controls how soft or firm the ride will be and how well they control the bumps you hit and keep the wheels planted to the road. They use gas, usually nitrogen in them to keep pressure on the oil to control the oil from foaming as it goes back and forth through the valving mechanism. Oil in your shock reacts to temperature the way engine oil does. When it's Minnesota cold, -25 and you hit a bump you feel it to your bones. Same shock in Florida, same bump, same speed and car and you have a normal "feel" to hitting that bump. Up here we have to be (should be) a little more careful what we hit a pothole when we first start out until that oil has warmed up from friction going back and forth. Most people in cold climates will blow a shock in the first couple miles from a cold start and not necessarily know it because everything is so stiff at first. It's caused by hitting something drastic when the shocks oil is too thick to be able to compensate for the hit. Photo, right rear shock mount blown out. |
| All times are GMT -5. The time now is 03:49 AM. |
