Rear Springs & Koni adjustable Shocks
Old Oct 3, 2008 | 08:22 PM
arzy's Avatar
Default Rear Springs & Koni adjustable Shocks
Hello
I have recently bought a set of king springs and Koni adjustable shocks for my t5r, my question is how do I install them? Also how do you adjust the koni's? are they adjustable once installed?
any help muchly appreciated.
Arzy from Oz
Old Oct 4, 2008 | 04:02 AM
S70driver's Avatar
Default RE: Rear Springs & Koni adjustable Shocks
Take them to a shop, that is how you install them.
Honestly not trying to be rude, but if you have to ask it probably isn't as job for you.
Now it isn't a terribly tasking job, but it does don't some work and time.
Personally I would have it done by a shop.
Also they are adjustable after installation.
Old Oct 7, 2008 | 05:30 PM
TOm93R1's Avatar
They are adjustable, but you have to remove the lower bolt and pull them off the stud so you can rotate the lower half of the shock. Pushing the shock all the way in and rotating is how you adjust it.
Rear shock and spring replacement is an easy job.
Old Oct 10, 2008 | 10:53 PM
arzy's Avatar
Thanks Tom93R
Have done it, piece of cake!!! easy install. Took about 2 hours from start to stop. Thanks again for a great forum!!
regards
Arzy
jorjelgt
Jun 2, 2014 10:03 PM
jorjelgt
Jun 19, 2013 12:34 PM
96850_R
May 17, 2011 09:41 AM
kapka42
May 13, 2011 02:33 PM
kapka42
Feb 28, 2011 04:41 PM
