Rear Suspension Bushing removal from trailing arm
Well, I've done all the easy stuff - removing bolts...Now I'm trying to get the bushing assembly out of the trailing arm. I've tried hammering, heat, digging out the rubber, pipe wrenching,... but it refuses to come apart.:mad::mad::mad:
Any suggestions would be greatly appreciated.:confused: |
put the one big bolt back into it (finger tight works, just enough to hold it). pb blaster the joint. give the trailing arm a nice wack.
Originally Posted by 850tony
(Post 166556)
This was one job that I'm glad is done and will avoid in the future if I can. |
glad u figured it out. volvo has a special tool to pull it....
(Post 166777)
