Rear wheel lock up
Old Dec 16, 2007 | 11:39 AM
katzeye's Avatar
Default Rear wheel lock up
Hi,
My wife got into the 850 wagon this morning after a snow storm, and as she was driving off the rear driver's side wheel thumped and locked up. It was just the one side and it released in reverse. But when she put it into drive it did it again. We also noticed that that wheel seemed to be riding particularly low in the wheel well. A google search impled that this problem (in general, not correlating with volvo's) indicated that this is a brake (Fluid? ABS?) problem, possibly corrilated to wet weather.
Has any one else had this problem? Any possible solutions?
Thanks.
Old Dec 16, 2007 | 04:44 PM
JimKW's Avatar
Default RE: Rear wheel lock up
Is the car riding so low that it is hitting the wheel? The riding low could be a broken spring. The wheel locking up could be a stuck caliper or the emergency brake is getting stuck. Them emergency brake is a set of small brake shoes inside the rear rotor. To me it sounds like two unrelated problems, but not really too sure.
Old Dec 16, 2007 | 08:20 PM
Maybe the E-brake shoe stuck or came apart.
Old Dec 16, 2007 | 09:55 PM
katzeye's Avatar
Thanks for the responses. We really appreciate the responses.
The problem with the e break solution is that we don't use the e break. Becasue it was having the relase problem years ago. Any other ideas?
Old Dec 16, 2007 | 10:14 PM
But that doesn't mean the e-brake shoe didn't come loose.
I have seen it before.
It is more prone to the 960's but happens to the 850's as well.
Old Dec 17, 2007 | 01:59 AM
JPN's Avatar
JPN
+1 to all.
I would have the e-brake fixed so you can use it. You probably know, that even on rear disc brakes, the e-brake uses drum-type shoes and if there was enough water present, it could have frozen but since it released in reverse, it may have been trailing shoe or the leading shoe. If you can work on a car, see attachment. If not, have a shop do it for you, preferably a shop that specialises in Swedish/European makes and insist on using OEM parts only.
The manual continues on as "...second and eighth notch. Install cover plate"
JPN
[IMG]local://upfiles/6892/CFF7BB9A16D44B5AB2022E2B85345248.jpg[/IMG]
Old Dec 17, 2007 | 08:40 AM
Psaboic's Avatar
Agree... Even if it is not the E-Brake, you need to get that fixed
crgolf
Feb 10, 2013 12:43 PM
kurdtpatton
Aug 19, 2010 09:38 PM
cganotisi
Sep 22, 2006 01:20 AM
Niel
Jun 7, 2006 08:54 PM
