replacement parts
Old Dec 1, 2005 | 04:05 PM
tomservo's Avatar
Default replacement parts
So I found a local Parts Plus store that has Beck Ankey (?) cap and rotor on hand, a little cheaper that Bosch, but are the parts as good? I'm really considering it, just so I don't have to wait for the shipping. Any thoughts?
Old Dec 1, 2005 | 10:54 PM
Default RE: replacement parts
I would go with the BOSCH They are the closest to OEM.
We use them.
Old Dec 2, 2005 | 05:03 AM
tomservo's Avatar
I went ahead with the parts from the store. I figure they should work fine. Got a Wix air filter, federal mogul wires, ngk plugs, and beck ankey cap and rotor. Price was right and I hope they'll be fine.
Old Dec 3, 2005 | 02:33 PM
robert213's Avatar
Beck /Arnley products are sold thru retail stores like CarQuest.
http://www.beckarnley.com/product.htm
Regarding Spark Plugs wires, take ohms reading of old OEM wires and new wires. Readings should be consistant between wires 1 thru 5. Unless you purchased performance wires, readings of new wires should be slightly less than old ones.
Regarding Cap and Rotor, it is desirable to have brass/copper contacts. More and more aftermarket vendors are switching to cheap aluminum. I prefer OEM and NAPA/Echlin http://napaechlin.com/. As long as you have brass/copper contacts, you will be fine. If you have aluminum, return and purchase another brand.
I use NGK plugs in all of my Japanese vehicles. With turbo'ed engines, stay away from expensive platinum, iridum, etc. I can easily go 30K miles with regular BPR6ES-11 and BPR7ES-11 plugs. With NGK, 6 is a hotter plug than 7, -11 is pre-gapped at 1.1mm (.043inch).
Plugs for our normally aspirated engines are:
Bosch Copper FR7DC, NGK BKR6ES or BKR6E (V-power), Autolite 3923, and Champion RC9YC.
and our turbo'ed engines are...
Bosch Copper FR7DC (FR6DC might be too cold), NGK BKR7ES or BKR7E (V-power), Autolite 3922, and Champion RC7YC.
and should be gapped at .028 inch.
T77911S
Jun 28, 2018 02:18 PM
JawdB
Jun 10, 2015 09:47 PM
Iamdagerman
Mar 4, 2013 12:27 PM
TacklaNHL
Jul 29, 2012 11:20 PM
andrew123
Canada, Over Seas & Elsewhere
Jan 9, 2011 05:09 PM
