Replacing bulbs in the dash
Old Mar 21, 2009 | 07:10 PM
Arsenal6's Avatar
Default Replacing bulbs in the dash
hi guys I want to replace the bulbs in the dash i just realized that they burnt out. I was wondering if there was a picture guide?
Old Mar 21, 2009 | 07:19 PM
rich nc's Avatar
not a big deal if you follow the instructions in a haynes manual to take off the dash top. seems like it is REALLY in 2 or 3 different sections of the book. the end caps come off, the speaker grilles are easily pried off with a small screwdriver, the glove box comes out (check your assortment of torx bits, a 1/4 inch drive here and there helps), the vents pry out to get to some screws and (i think) you have to take out the passenger airbag so BE SURE to disconnect the battery! be prepared for a lot of broken bits of plastic (vovo plastic is pretty bad). reach behind the panel to unplug the unit and lift up and out.
pretty fast work, can remove the top in about 20 min w practice! lol (been under there a LOT trying to fix odometer!!! )
Old Mar 21, 2009 | 08:45 PM
nonsense619's Avatar
heres a written guide
https://volvoforums.com/m_17710/tm.htm
and a picture guide
http://volvospeed.com/Dashremove.php
i would also change the odometer gear while in there..these are known to go bad and its fairly inexpensive
Volvo_Neps
1998-2000 model year V70
Sep 12, 2024 06:53 AM
lsmith49
Nov 13, 2012 11:53 PM
tr_car_nut
Jan 19, 2008 09:37 AM
panopticon
Mar 21, 2005 09:38 PM
Erock198
Aug 3, 2004 02:09 PM
