Reprogramming key fobs
Old Jan 19, 2006 | 06:30 PM
MacGregor's Avatar
Default Reprogramming key fobs
I have heard a few different techniques for reprogamming key fobs. None have yielded any results yet. I have 2 850 Wagons and 5 remotes of the same type. On 1 of the wagons 2 remotes work with it. The others cannot be programmed to work with either vehicle.
HELP!!!!
MacGregor
rob@theitpeople.com
Old Jan 19, 2006 | 06:47 PM
info2x's Avatar
Default RE: Reprogramming key fobs
The two that work... did you program those or did those already work?
Old Jan 19, 2006 | 06:54 PM
MacGregor's Avatar
They already worked.
Old Jan 19, 2006 | 07:16 PM
info2x's Avatar
What methods did you try? I'm sure someone who is better than I could probably tell you that your right, wrong, or that you should check the batteries.
Old Jan 19, 2006 | 07:24 PM
MacGregor's Avatar
The method was the following:
turn ignition to the on position (but do not start the car) 4 times. On the fourth attempt press and hold any button on my remote and it should be reprogrammed to the cars transmitter.
I checked all batteries in the key fobs and they're fresh. I tried all 3 key fobs = no joy. I tried pausing for a second at the end of each ignition cycle - nothing.
I am out of patience. I was hoping that these key fobs would allow me to get the v70 white doorhandles that have no key hole in them... looks like I lose.
Old Jan 19, 2006 | 07:27 PM
info2x's Avatar
Assuming your method is correct (because I have no clue) it could be possible that the fob has died. I don't know what a replacement would cost, but I wouldn't imagine it would be too bad.
Old Jan 19, 2006 | 09:32 PM
JimKW's Avatar
Try turning the ingition on and off five times. That's what I seem to remember.
Old Jan 19, 2006 | 11:05 PM
Mass850's Avatar
Absolutely as Jim suggests, its, or at least it is on mine, 5 times and leave ignition on at the 5th time.
I did this a couple of days ago with a remote from ebay and it did the trick.
Good luck.
drvolvo
Aug 14, 2018 02:36 PM
billshoff
Oct 4, 2011 09:56 PM
andy007aw
Feb 18, 2010 01:25 AM
bmwquick
Feb 15, 2010 05:24 AM
spunkymonky
Jul 6, 2009 01:25 AM
