scary BUZZ Noise is worse - Videos w/ sound of noise included
Old 08-07-2007, 06:39 PM
ludeless's Avatar
Default RE: scary BUZZ Noise is worse - Videos w/ sound of noise included
I was kinda thinking of using a bunch of 2x4's or 2x4's and stacking them up instead of jackstands. From what i remember of the underside of the subframe, was that it's got an upward curl to it, and sometimes shifts when I'm lowering onto my stands. Dunno if long wood braces would be much better.
Do you happen to know if the bolts (for the trans housing or innards) are re-useable, or should i plan on having new ones on hand? I remember the specs saying that new botls should be used for the control arm to subframe?
  #22
Old 08-07-2007, 06:59 PM
You can replace the torque converter bolts.
The rest will be fine.
Did you see the before and after pics of my car?
I cleaned it this weekend.
  #23
Old 08-28-2007, 07:14 PM
ludeless's Avatar
The car going into the shop in a week from today! Getting ready to order all my parts hopefully tonight for the other stuff besides the transmission i'm going to replace. Just got a few questions and wanted to make sure i wasn't missing anything. Here's what i'm thinking of replacing
Transmission
Torque Converter bolts x6
Rear Main Seal - is this the same as "9458178 Rear Crank Seal" ???
RH and LH Driveshaft Seals
LH Driveshaft
LH Wheel Bearing
Water pump
Timing Belt Tensioner (I did the timing belt about 10k miles ago, but haven't done the tensioner yet)
Timing Belt idler pulley (same as above)
Oil Pan Seal
Possibly the engine mounts?? Don't know if they need to be replaced or not.
Anything i'm missing?
Can you think of any special tools i'll need Tech?
Thanks!
xwang
02-14-2017 06:21 PM
Ahmed
05-25-2014 09:04 PM
mikey4040
11-05-2011 05:45 PM
ddub
08-28-2008 05:18 PM
Quick Reply: scary BUZZ Noise is worse - Videos w/ sound of noise included
