Seat Belt Removal
Old Jun 5, 2007 | 06:36 PM
J Telectro's Avatar
Default Seat Belt Removal
My 96 850 has holes in the seat belt release buttons (red-orange
buttons). It looks like the sun and maybe some long fingernails did
the damage. I have another set from a 95 850 that I would like to
use as replacements. A couple of questions:
1. Is there any way to get the bolt out that holds the seatbelt/buckle
assembly to the seat without removing the seat? (And of course get
the new one back in).
2. I remember seeing something about a recall on the 95 850's
for a seat belt problem. Does anyone know if the buckle assembly
was the cause for the recall? I don't want to put these in if they
are not safe.
The only other solution I can see is to disassemble the buckles
and replace the red-orange buttons. It looks to me like these
buckles are designed to not be disassembled. If anyone has
successfully disassembled and reassembled one I would appreciate
any information you can give me.
Thanks, John
Old Jun 5, 2007 | 06:46 PM
Default RE: Seat Belt Removal
Best to do would be to pull the seat and replace.
It is only 4 screws and will take about 5 minutes to pull it out.
Old Jun 6, 2007 | 05:04 AM
J Telectro's Avatar
Hi tech,
Ok, thanks. One more question, I know I have to disconnect
the car battery, but do I need to do anything else before unplugging
the wiring underneath the seats? (I have airbags in the seats).
Thanks, John
Old Jun 7, 2007 | 05:37 PM
The Air bags aren't electronic controlled.
Remove the switch panel and on the back side of the panel is a red clip. You need to install it between the 2 metal pieces at the front side of the seat. If those 2 metal connections touch that will set the airbag off.
Old Jun 8, 2007 | 04:42 AM
J Telectro's Avatar
Ohhhhh........
That makes it easy, I was worried about setting a code or something.
Thanks, John
TacklaNHL
Feb 21, 2026 04:11 PM
RobJamesInSheffield
2001-2013 model year V70
Apr 26, 2015 03:03 PM
craigshensel
Apr 13, 2012 04:07 PM
AnEskimo
May 16, 2010 06:19 PM
fjkai
Jul 2, 2009 07:37 PM
