Security Module/Alarm system '96 850 GLT
A couple years ago, the alarm in my '96 850 (now 175k) started chirping and blinking without any apparent reason. Being 75 miles from home on a sunny fall afternoon, we drew a lot of unnecessary attention on the PA Turnpike. As a temporary solution, we pulled the fuse to make it stop, but we lost the central locking function and use of the fob. I later discovered than one of my son's friends (you know, the kid who can look at something and break it) had broken the lock on the passenger front door where the button protrudes through the door trim. I had that fixed, but when I replaced the fuse the erratic chirping and blinking resumed. My mechanic and I scoured the car for a short, but found nothing.
I am replacing the driver's seat on the 850 this weekend with a seat from a '98 V70 XC. My question is, can the security system be reset? If not, can I use the security module from the donor car for my seat ('98 V70 XC)? I figure, with the seat out, it will be a good opportunity to get up under the driver's side of the dash to pull the module from the donor car, and replace the module in my car before I install the new seat. Any thoughts out there? Thanks!
The 850 Alarm system is not compatible with the VGLA system from S/V70.
The 850 had 3 different alarms:
- Volvo alarm : it engages by turning the key in the lock and also with the Fob which has the 2 buttons placed in the same height
- Guard 1 : can be activated only by the remote and has a receiving panel placed in the middle of the A-pillar on the drivers side
- Guard 2 : can be activated only by the remote and has an Fob with two buttons different in size and placed one above the other.
Normally if everything works you should be able to kill the alarm with the Fob.
fhsscrballa
1998-2000 model year V70
09-08-2013 01:34 AM
850massa
12-30-2010 05:24 AM
