service light re-set?
93 850 GLT
Can't seem to find the info to re-set the service light after it comes on due to mileage. There is no small re-set button on the cluster. The light comes on upon start up and goes out after a few minutes. Can someone help? Thanks in advance, Dave in Whistler, B.C. |
RE: service light re-set?
Hello Dave,
Greetings from Chicagoland. Here's the procedure: 1. Turn the ignition to the 2nd detent, put the test lead at the diagnostic terminal in A7. 2. Press the button on the diagnostic terminal 4 times. This makes the LED stay on. 3. Press the button once, wait until the LED comes on again, then press it for another 5 times. Wait until the LED comes on again, and then press the button once. 4. After above procedure, the LED flashes and the service remainder should disappear. 5. Turn off the ignition, stow the test lead and turn on the ignition switch again to the 2nd detent to verify the light turns off. Good luck, JPN |
