service light re-set?
Old Dec 6, 2006 | 10:59 PM
hillfolk's Avatar
Default service light re-set?
93 850 GLT
Can't seem to find the info to re-set the service light after it comes on due to mileage.
There is no small re-set button on the cluster.
The light comes on upon start up and goes out after a few minutes.
Can someone help?
Thanks in advance,
Dave in Whistler, B.C.
Old Dec 7, 2006 | 12:05 AM
robert213's Avatar
Default RE: service light re-set?
https://volvoforums.com/m_3636/tm.htm
https://volvoforums.com/m_15504/tm.htm
Old Dec 7, 2006 | 02:55 AM
JPN's Avatar
JPN
Hello Dave,
Greetings from Chicagoland.
Here's the procedure:
1. Turn the ignition to the 2nd detent, put the test lead at the diagnostic terminal in A7.
2. Press the button on the diagnostic terminal 4 times. This makes the LED stay on.
3. Press the button once, wait until the LED comes on again, then press it for another 5 times. Wait until the LED comes on again, and then press the button once.
4. After above procedure, the LED flashes and the service remainder should disappear.
5. Turn off the ignition, stow the test lead and turn on the ignition switch again to the 2nd detent to verify the light turns off.
Good luck,
JPN
tngreg
Sep 5, 2022 07:27 PM
rred
Jun 28, 2011 08:45 AM
kijjh123
Sep 15, 2008 11:50 AM
mstrplmber
Aug 28, 2008 03:34 PM
soulfulimpressions
Jul 31, 2008 07:07 PM
