Service Reminder
1995 850 turbo.
Does the service reminder reset when you unhook the battery? Like every other Volvo with a analog odometer the OD does not work, has not worked for well over a year and I have been using the trip OD in the info display paired with the maintenance reminder to tell me when the oil needs to be changed. However I replaced the alternator a few weeks ago and of course that reset the trip OD and like a idiot I did not write down the miles and it reset to zero. So my question is, does the maintenance reminder reset when you unhook the battery? Or can I count on that to still light up when it reaches 5,000 miles? |
No, you have to reset it with the OBD-I port near the ECU box behind the right headlight. There are instructions in the DIY Sticky.
1 Attachment(s)
The panel next to the washer fluid reservoir filler.
Thank you guys.
I know how to reset it, I printed the instructions when we got the car and keep them in the glove box so when I change the oil I can reset the service reminder. I just did not know0 about the battery being disconnected. Thanks again guys. |
Man, you can pull the bulb on the reminder. It's an idiot light.
Originally Posted by rspi
(Post 306209)
Good catch. Maybe other's are using the same method. ;)
1 button press wait for light
4 (count thoushand) same as above 1 (count) ditto 5 (thos) ditto 1 (press) ditto light should flicker. 14151 is the code make sure key is in #2 position if it dosn't take try again |
