Slight Hesitation
Old Oct 6, 2006 | 12:52 AM
John124's Avatar
Default Slight Hesitation
I have a 1993 850 GLT sedan that periodically hesitates or hiccups. This usually happens at about 35 mph. During the "hiccup" the check engine light briefly flashes.
Can anyone enlighten me as to what could be causing this?
Thanks.
Old Oct 6, 2006 | 01:00 AM
Default RE: Slight Hesitation
Maybe a missfire due to bad spark plugs or wires.
Old Oct 6, 2006 | 05:31 AM
strangedays's Avatar
If you've checked the plug and wires, and gone through things like the distributer cap and rotor, you may find the problem lies with the ignition coil, which has been my issue recently, get some ignition spray and spray it all over the coil to see if it improves.. Ive found you need quite a bit though.
Old Oct 6, 2006 | 03:41 PM
code33's Avatar
Pull the code(s). That'll provide a better idea to determine the problem.
This will guide you:
http://www.troublecodes.net/Volvo/
Will1147
Jul 28, 2013 02:21 PM
counterspyder
May 29, 2008 10:02 PM
John124
Oct 6, 2006 12:52 AM
blaackone32
Apr 4, 2005 09:40 PM
