smell fluid
Old Jan 6, 2006 | 06:30 PM
cool_kyle_3000's Avatar
Default smell fluid
when i drive my car it is fine but when i stop then i can smell something burning i think it is fluid but i dont kno what and it is up against the fire wall is where the smell smells the strongest and the tiny amount iof smoke is commin from. could it be a bad hose?
Old Jan 6, 2006 | 09:42 PM
Default RE: smell fluid
cracked radiator?
Old Jan 6, 2006 | 10:18 PM
reg's Avatar
reg
I'm assuming the smoke is on the engine side of the fire wall? Is it sweet smelling? Have you checked the level of your antifreez?
Reg
Old Jan 6, 2006 | 10:39 PM
If your car is turbo I will bet that the turbo return line o-ring is leaking oil.
You need to get under the car and look.
Old Jan 7, 2006 | 01:03 PM
rp850's Avatar
Do what tech said and check the oil return line. Oil return line is #1 culprit and a $3 fix by replaing the seals. It could also be that oil is making its way to the back of the exhaust manifold and burning. If you pull the plastic cover over the spark plugs and see oil under there you have a problem. You could try replacing the oil cap and seal (Volvo redesigned it) or it could also be a loose connection on the oil trap hose that connects up there.
rp850
Aug 8, 2014 09:04 AM
V70Pinner
May 30, 2008 06:38 PM
gary5461
Nov 28, 2005 09:24 PM
mywifescar
Apr 1, 2005 08:22 PM
ignacio
Sep 17, 2004 03:16 PM
