Squeek Squeek wagon interior
95 850 wagon- Squeek Squeek Squeek- driving me loopy! I did one of those hatchback interior panel kit things about 6 months age. still sqeeeks. As a test I cut two 40" sticks to wedge between seat and hatchback panel, fit them high, fit them low. still squeeks. so maybe the panel is ok. Co worker's advice- turn the radio up. Yeah, ok, well it would really be cool if I could just get the squeek un squeeked- you know??? Anyone have a similar squeek on your 855? Dave
I had a few rattles in the back of my wagon and found a few clips broken from some of the trim pieces. You have to track them down and figure out how to stop them.
squeeky
RSPI- think I've found it- the floor panel right behind the rear seat. propped it up and drove home- no squeek. All this time I thought it was the hatchback. D
Wait, where?
That is the same problem I am having now, I need to take a look at it. Your talking about that panel behind the seats that covers the rear shock mounts right? If so what ended up being the isssue. Did you just need to tighten the bolts up? Because the squeaking on my car is rediculous to.
squeek
mattn- I think thats the one. It hinges up. Well I found the place, havent solved how to fix yet. I might try removing the metal snap clips and see what happens. put them back if the panel bounces around. Dave
Oh okay than im having the same issue. I am actually going to use rubber in between the metal hinges so there no metal to metal contact. Everything in my car that rattled I have tightened down and all squeeks, I unsqueekafied by using rubber...rubber washers......rubber sheets..etc. Good luck
squeek
mattn- where is Wappingers Falls? I'm near Syracuse. D
Right near Poughkeepsie, little town...
| All times are GMT -5. The time now is 12:25 AM. |
