Squeek Squeek wagon interior
Old Oct 20, 2011 | 01:41 PM
daver80's Avatar
Default Squeek Squeek wagon interior
95 850 wagon- Squeek Squeek Squeek- driving me loopy! I did one of those hatchback interior panel kit things about 6 months age. still sqeeeks. As a test I cut two 40" sticks to wedge between seat and hatchback panel, fit them high, fit them low. still squeeks. so maybe the panel is ok. Co worker's advice- turn the radio up. Yeah, ok, well it would really be cool if I could just get the squeek un squeeked- you know??? Anyone have a similar squeek on your 855? Dave
Old Oct 20, 2011 | 02:21 PM
I had a few rattles in the back of my wagon and found a few clips broken from some of the trim pieces. You have to track them down and figure out how to stop them.
Old Oct 21, 2011 | 08:30 AM
daver80's Avatar
Default squeeky
RSPI- think I've found it- the floor panel right behind the rear seat. propped it up and drove home- no squeek. All this time I thought it was the hatchback. D
Old Oct 21, 2011 | 01:35 PM
boxpin's Avatar
Wait, where?
Old Oct 21, 2011 | 11:58 PM
mattn888's Avatar
That is the same problem I am having now, I need to take a look at it. Your talking about that panel behind the seats that covers the rear shock mounts right? If so what ended up being the isssue. Did you just need to tighten the bolts up? Because the squeaking on my car is rediculous to.
Old Oct 23, 2011 | 09:47 PM
daver80's Avatar
Default squeek
mattn- I think thats the one. It hinges up. Well I found the place, havent solved how to fix yet. I might try removing the metal snap clips and see what happens. put them back if the panel bounces around. Dave
Old Oct 24, 2011 | 05:27 AM
mattn888's Avatar
Oh okay than im having the same issue. I am actually going to use rubber in between the metal hinges so there no metal to metal contact. Everything in my car that rattled I have tightened down and all squeeks, I unsqueekafied by using rubber...rubber washers......rubber sheets..etc. Good luck
Old Oct 24, 2011 | 03:57 PM
daver80's Avatar
Default squeek
mattn- where is Wappingers Falls? I'm near Syracuse. D
Old Oct 25, 2011 | 10:30 PM
mattn888's Avatar
Right near Poughkeepsie, little town...
daver80
Jun 25, 2011 10:08 AM
jpjmustang
Jun 3, 2011 09:56 AM
pconfar
Feb 10, 2011 09:43 PM
cjaama
Dec 12, 2009 07:23 PM
cool_kyle_3000
May 30, 2006 10:56 PM
